YW. I have used the recipe creator a couple times recently to save modified versions of that posted.
Let us know your results with the recipe from Hoos.
@brian.mchenry.bmrul1
Thanks for the tip! I either had something stuck somewhere in the roaster or I must have stored some of the beans in less than ideal conditions as I have not had any more smell/taste related problems since I cleaned the machine and switched beans.
I have also switched to hybrid Morten Munchow(CoffeeMind) roast approcach which has been giving me great results so far.
Cheers!
Is there a bullet point/synopsis of this approach somewhere? His course introduction wore me out
There’s a little bit in this discussion:
Basically:
Thank you.
Basically he’s advocating for a flatter roast profile with 25% development. I’ll give it a whirl but IME that usually results in flat, baked results. Maybe effective with coffee’s that are too bright and need that tamed.
There’s been a formula discussed elsewhere where the temp change from 1C to drop is divided by the time in seconds. I usually had the best results in my Huky with something in the 7% to 11% range.
I’ve kind of started using the Munchow approach… kind of.
I tried a few roasts with only 2 power changes with the drum and fan static. First change being around yellowing and second before FC. Although I am not constantly going for 3min development I have been getting good results so the approach seems to be pretty good.
I’m not making many heat adjustments any more either. After yellow and 15 degrees before 1st.
Munchie and Hoos’ sample method sound somewhat similar but with a shorter development and overall roast
