About the R2 & R2 Pro Specific category
This category is for subjects only specific to R2 & R2 Pro.
Curious if anyone has come up with a way to keep the door open on the R2 or R2 Pro. At least you could wedge the tryer in before. Now you have to hold the door open for all the beans to exit.
Rubber band would probably melt
magnet on end of door knob and bottom of panel might work if the magnet doesn’t screw up anything inside the control panel
Would an R1 door fit on ? Seems like the knob has to be heavy enough to keep the door closed but a latch of sorts might make sense?
FWIW if you find the right length bungee cord with s-hooks you can loop it around the handle and put the hooks together behind the display. Mine are the heavy rubberized ones and so far aren’t affected by the heat.
