After I upgrded the firmware in the bullet to the latest today the voice is now mostly static.
Anyone else have this problem?
I have had the same problem and fixed it by going in to manual bootloader as described in below posts.
Hope it helps, Cheers!
(ps. Just noticed I linked wrong, but you should be able to see all posts if you click the title)
I don’t believe a firmware update or restore fixes this. You need assistance from support@aillio.com to restore the nice lady…
An update will most likely not fix it, correct. The part about manual bootloader will most certainly!
Hope it works out, cheers!
if the bullet works normally but the sounds are not then please contact Aillio support
