Air Quality Index analysis while dumping beans
Hi Roasters. I’m providing some air quality index (AQI) information that I think will interest you. I recently acquired an AQI analyzer because I was curious about exposures while roasting.
First some information about my setup: I use an in-line fan exhaust system that vents to the outside. I roast in my garage so I always have a big floor fan circulating a lot of air for my own comfort (it’s hot in Florida in the summers!) I am including a picture of my setup.
In short, the AQI meter indicates that everything is A-OK while roasting with my setup (see the still photo of the meter)
. What really surprised me was what the meter indicated during dumping of the roasted beans; the air quality deteriorated rapidly well beyond the point where the analyzer went into alarm. I have included a photo showing the meter at its highest reading.
In the photo you will see that the bottom/center number is the AQI, the bottom/right number on the meter indicates Particle Matter less than 10 microns (PM10), and the number right above PM10 is the PM2.5 indicator (Particle Matter less than 2.5 microns. Particles this small can enter the lungs and even the blood stream. This photo was shot with the meter sitting within a foot of the cooling bowl.
I repeated the measurement on a subsequent dump with the meter closer to my body, or within 2-2,5 feet. The photo of that dump will show that the AQI near me was still not good but the analyzer did not go into alarm.
In the future, I will keep as much distance as I can between myself and the cooling bowl while still being able to stir the beans, and will wear a mask like those we’ve all worn during the Covid pandemic.
Finally, I found an article regarding a study performed by an environmental agency at a coffee roasting and packaging facility. (https://www.cdc.gov/niosh/hhe/reports/pdfs/2016-0080-3324.pdf In short, all employees involved in the process showed above acceptable exposure limits for various compounds related to coffee roasting and packaging. What I gather from this is that I should do my best to limit my exposure while enjoying my craft! Maybe you will come to the same conclusion.
Do you have a vent hose from the back of your cooling tray to vent out? If not, I wonder what the AQI would read if you have a hose that directs the fumes outside. In my setup I have a hose from the cooling tray to direct the fumes to my range hood vent that is on during roasting. I think many of us have a hose to vent out the cooling tray fumes.
Hi blacklabs. No I do not, but a hose at the cooling tray exhaust is now on my list of improvement. Thanks.
Let us know how that AQI reading changes after that improvement… I’m curious! :slight_smile:
I have an exhaust tube on my cooling tray, and I also see out of healthy region AQI levels when dumping beans, but all good when roasting. I don’t have as fancy of an AQI meter, but I do have a meter that is connected to my air purifier that lets me know when things are out of healthy region. Currently I’m using an inline 6 inch AC Infinity, which adapted to pull from 4 inch ducting and split 50/50 between the cooling tray and exhaust area of the roaster. I think it would be possible to create some sort of adapter that could pull some air from just under the exit of beans from the roaster and also from the normal exit from cooling tray and then y-into a 4 inch male exit. I have a picture in my head, but that’s hard to explain. Think of something like a hardwood floor vacuum cleaner attachment, that might have a curve around the roaster exit to get as close to the exit as possible, which would then meet up with the 4 inch coming out of the cooling tray.
Big concerns definitely for long term health.
Not only the smoke from the beans, but the plastics can heat up significantly enough that I wonder about fumes from those. Though if you smell plastic burning, it is probably a sign that your roaster is not working properly.
Thanks for sharing about the air quality and it is a good reminder to make sure ventilation is a priority.
Air quality is something I have been interested in for many years. Living on the West Coast, we now have a fairly regular “fire season” and I have been tracking indoor and outdoor air quality to help minimize my family’s exposure during smoke events.
So after reading this post last year, I moved one of my sensors into the roasting corner in my garage. My venting strategy involves two Cloudline fans vented to the outside. The 4" fan is dedicated to the cooling tray and runs on full blast when I’m dumping beans. I run the 6" fan for the bullet exhaust on about 50% speed.
Here is a photo of my setup:
To my mild dismay, there is still a noticeable spike in pm2.5. I do see similar spikes for air quality in my kitchen when cooking (or even higher) so this isn’t horrible, but I was hoping for it to be very low or undetectable.
I need to log my time more carefully during my next roast to try and mark on the graph when the beans are dropped. I suspect most (maybe all) the pm2.5 is released at that point.
Uh oh, this is rather worrisome. I thought venting the roaster outside and adding a dedicated hose to the cooling tray would be enough, but it seems like it needs more work.
To the person who suggested wearing an N95 mask while dropping the beans, would that be sufficient to filter out the small particles and VOCs? I think you’d need something more robust, such as a 3M respirator fitted with these cartridges:
I just invested in an AQI monitor from Amazon to test my own environment and report back here with some numbers.
Guys, you might be worrying about nothing.
Would this air quality reading be any different to that from any other baking, frying or cooking process we do as part of everyday food preparation ?
If what you are measuring is temporary and you are only exposed to for just a few seconds as opposed to being part of an ongoing and lasting climate then I wouldn’t worry about it.
Being close to a charcoal bbq or a camp fire might be worse for your health than roasting coffee on this small and infrequent scale.
:blush:
I wouldn’t describe my feelings towards indoor air quality as worried per se. More that I am interesting in fully understanding when and how much particulate (and VOCs) pollution I am exposed to as part of my daily life.
Cooking, especially frying, will create a massive (90-120+) spike on a sensor. As will my spouse blow drying her hair. Also, we have many days (over a month once) when the outside air quality was well into the 60+ μg/m3 range. I can’t even imagine the numbers experienced around a campfire or a charcoal bbq.
Also, there has been some research indicating that the particulate and VOCs released during roasting may be especially bad for you.
I think it is something to be aware of and to take reasonable steps to minimize, but as an infrequent home roaster, I don’t think I would bother with a mask.
Your spouse probably has a blow dryer with an ionizer, and any ionizer will release ozone, so that’s what’s being picked up by your monitor.
Roasting anything, not just coffee. gabyritaseek.qiAO has said everything already, but I’d like to add that, when roasting or frying anything, the amount of toxicity will be determined by the level of roast. So, if you like your coffee burned beyond recognition, it will be especially bad for you. The food that you over roast or over fry will add other risks when ingested. Coffee won’t, as long as you brew it, but if you eat burned beans it will have negative effects.
Can’t say for sure if it’s due to pan roasting beans for a year under a weak kitchen hood but my respiratory health seem to have worsen after starting to roast. I don’t smoke, drink and doctor said everything is fine after CT/X-ray scan.
I had Pulmonary Tuberculosis (a lung infection) in my early childhood so my lungs might be more sensitive to particles and smoke, especially during colder months.
Nowadays I make sure to wear a mask (KF94 here in Korea) whenever I roast. And urge others who have had or has a respiratory health issue. Happy roasting!
Well, that’s more of an advice on proper ventilation than wearing a mask. Unless you wear a mask 24/7. Any harmful components must be ventilated outside. If they stay for too long indoors, they will bring nothing but health risks. Also valid for any kind of roasting, frying and burning in general, like a fireplace or any heater that relies on burning anything. You are continually exposed to many risks outside, and outside is already ventilated but it didn’t do the trick. The spike that you see on your meters when dumping the beans is something that goes away very quickly if you’re ventilating properly. You shouldn’t have any smoke where you’re roasting during the process. The AQI will have spikes when you get your roasted potatoes or whatever out of the oven, or when frying them if you don’t have proper ventilation. If you have a good setup, you won’t need a mask. If you don’t, please stop roasting indoors and go on a balcony or something, because a mask won’t save you, and get proper ventilation before going back indoors. I feel like there’s something I forgot to say… Oh, yes! Proper ventilation.
Also, if you do have some sort of medical issues, just consult with your doctor before doing anything. Better safe than sorry.
Here are my results with an R2 Pro in our garage. The fan vents to a duct sweep with about 4" air gap. It travels through an AC Infinity filter and then out the garage through flexible hosing. The system is powered by a 6" AC Infinity fan. There is an elbow to which a separate 4" hose is connected to the fan on the cooling tray. So the entire system is vented.
Air quality during pre-heating (no beans in the roaster)
Air quality after dropping beans
What I found interesting in my setup is that the particles accumulate with time. My scores go up with each roast and stay there once it reaches the “Unhealthy for Sensitive Groups” level. So, even after finishing the last roast, the air quality in the garage is still moderate or unhealthy based on this monitor.
The good news is that VOCs never reached an unhealthy level throughout the entire roast, so the fan is doing a good job venting the smoke.
That is interesting.
Excuse me for asking:
Is it still showing the last particulate values before you start roasting on a new day?
Have you tried using it in another room to see if it resets?
Yes, the monitor (Temtop LKC-1000S+) is quite responsive. I see the values changing regularly. When I roasted today after measuring yesterday, all the values started out very low (monitor: “Good”) and gradually increased to higher levels (monitor: “Moderate”). In today’s roasts where the drop temperatures were 203-205 ºC, the monitor never reached the “Unsafe for Sensitive Groups” level, but yesterday, when I dropped beans at 210-215 ºC, I did get that warning and it remained there for a while.
Greetings
Something unusual and frightening happened in today’s roast, which you can see here:
Everything was going fine when, all of a sudden, I smelled the intense aromas of the roast, much stronger than ever. My Temtop reported very high PM 2.5 and 10 numbers and the unit showed HAZARDOUS in red on the bottom. I immediately put on my N95 mask and dropped the roast a bit early (20% development instead of 23%).
It’s odd, because my 6" AC Infinity fan and ventilation were running one notch short of max and seemed to be working properly, but the aroma was quite intense. After running to grab my phone from inside, the monitor still showed a high value:
Mind you that “UNHEALTHY” is one level before “HAZARDOUS” on this unit.
In 85 roasts, that has never happened before. What do you think could have caused it? I thought perhaps something was on fire, but there was no indication of that or smoke coming from the R2 Pro.
Your crossover is a lower than it should be. Maybe it was overheating in some way?
I have a R1 V2 and am in ~470 roasts, most between 900g and 1kg.
I recently was having some issues with my roaster (seeing symptoms of being too hot) and had to take a deep dive with @da_kevin on IBTS and bean crossovers. What I learned is (to quote Kevin directly)“you should see a crossover between the IBTS Temp and Bean Temp near First Crack (195°C-205°C, 383°F-401°F).” On the profile you posted, you are at 167 C for crossover. This could indicate a dirty IBTS sensor as a simple solution. Why this matters (you probably know but this part is for those who don’t) is because the Bullet relies on the IBTS sensor readings to heat the Bullet. If the IBTS is reading a lower temperature than what it actually is, then it will heat more (more than it would with an accurate reading) and potentially be too hot.
I cleaned the IBTS sensor (learned I needed to be gentle and too rough to create an air gap where it’s seated), had to make sure the IBTS sensor was seated correctly, and did a very thorough maintenance to try and remedy the problem. This helped bring up my crossover decently, but for me that didn’t fix my crossover issue entirely. I had to order a new bearing and when ordering, I also bought additional parts that if needed to replace would keep me from roasting, including an exhaust fan impeller.
I installed the new bearing and thought I would give the new impeller a try to see if it helped. For me my problem has been fixed. I think the exhaust impeller was the final part of the problem. I’m going to put the old one back on and see if the issue comes back.
Cleaning regiments and methods suggested online (not Aillio) to clean the impeller might be a little rough on the aluminum and cause damage (even just slight damage) which could then cause exhaust issues.
I have focused on a good bit of my past few weeks trying to understand what might be causing my heating issue. Lately I have also been aware and thinking about air quality in the room I’m roasting. After reading this post, I’ll be taking a deeper dive into that.
