Does the Electronic motor moves constantly, once switched on? I had an error code 6384 once I started to roast. And seems like will have to change the motor, as going through the manual nothing relates to my case. Even though the roaster is new, roasted just 10 batches.
I am not sure which electric motor you are referring to, there are several in the Bullet. If you are on the latest 610, then the exhaust blower should always run a little bit. If it stops, check that the chaff collector is correctly installed, as there is a switch that will be activated to turn on the fans.
Yeah, that was the case with a switch. I guess I didn’t install chaff collector properly before. But at least I know my bullet way better. ![]()
