Artisan and RoasTime on the same laptop
I have recently added an Exhaust Air Probe to my Bullet R1 V2. RoastTime does graphs out the Exhaust Air on my profile but does not give any readings. I am looking to try out Artisan to see if I can get readings as well from the probe on my profiles. That said, I do not want my setup, which is very stable with RoastTime, to start misbehaving due to possible driver and other conflicts.
Can Artisan co-exist with RoastTime on a laptop without any issues? I will be using one of them at a time while roasting.
TYIA
If not being used simultaniously both Artisan and Roastime can be installed and you can use them interchangeably. Do NOT however try to open both at the same time - this won’t work.
