Back-to-back recipe roasting
I’m using an R1v2 to supply my coffee trailer, so I’m basically doing ultra-small-scale production with it. The Bullet is the perfect tool for me - it’s compact and has good instrumentation/automation tools. I’m just ramping up to the point where I roast about 3kg of a given bean in a session, usually in back-to-back mode, and usually with a recipe.
A very frequent error I make is following the instruction to “charge!” without remembering to manually restart the recipe. Then I have to either finish that roast manually, or dump, reheat, recharge.
Is there any way to make back-to-back mode always restart the current recipe? Or apply a recipe to a roast that is in progress?
Hi @dsjstc.Xfjs ,
Do you mean you select the recipe every time you preheat?
If so, you may want to disable Single-use Recipes in Edit Settings → Roast Config. This will make the recipe persist when switching to the next cycle.
LOL. That was it, can’t believe I missed that in the settings. Thanks so much!
