I bought 5 pounds of Bali Blue Moon Organic from Happy Mug and have done a first roast to a finish of 426.2F IBTS. After four days of rest the cup is very tasty with some brightness, thick mouthfeel, a mix of dark chocolate and earth, low bitterness, smooth, a touch of sweetness. Just wondering if anyone else has roasted this bean and, if so, did you get more chocolate at say 430-435F, or is 426 far enough? I was shooting for 15 seconds into 2nd crack, but even with a stethoscope in the tryer hole I’m not positive I heard 2nd crack; so, in the interest of not going too dark I ended it there.
I haven’t roasted this exact Bali Blue Moon lot yet, but I’ve roasted the very similar Sulawesi Toraja Pango Pango on the Bullet R2 multiple times.
Second crack on these wet-hulled beans is often surprisingly quiet, but you will definitely hear it with the stethoscope (at least I hear it with my stethoscope, usually closer to 427+ °F).
If you want even more chocolate and body while staying in clean light-oil Vienna, I recommend dropping a bit higher next time at 430–435 °F IBTS and targeting a DTR of 25–28 %. Out of curiosity, what DTR did you get on your roast at 426.2 °F? At that temperature you’re still on the lighter side of Vienna. These beans definitely tolerate and reward higher temps.
I tried a curve that had been working for finishing at 410F and my DTR at 426.2F was about 29%. I did a second roast of the Bali three days ago and ended at 431.4F, using some different parameters and ended up with a DTR of almost 36%. I’m not used to going darker than about 415F, so my curves don’t look very good. Still, the coffee has come out tasting very good both roasts. I have linked the two roasts below.
Thanks for sharing the curve and the update on your second roast — really appreciate it!
Glad to hear both roasts are tasting very good already.
On this latest one ending at 431.4 °F with ~36% DTR, you’re getting solid results, but targeting a lower DTR (25–28%) will improve the cup even more with better balance and sweetness.
Looking at the curve, the development phase after first crack is running quite long. To drop the DTR, the roast needs to slow down a bit post-FC — on the Bullet the fan is your brake, so increasing F in the right places will do the job.
For starters, I’d recommend going to F4 at 10:15 / 394 °F and see how that works. After that roast you may need to increase fan even further to slow it down more if the DTR is still too high.
Curious to hear what your DTR ends up at on the next one!
I appreciate the suggestions. I’ve been wondering how to handle development time with darker roasts. I could make some simple adjustments and get good dry and Maillard times, but then getting up to 430F-435F in a timely manner would almost certainly require upping the power after first crack, and that would result in a huge uptick of the IBTS. I will try using the fan more in my next roast. And I will be sure to keep you up to date on how it goes.
That has been my experience too. A lot of the beans I roast actually need a power boost almost immediately after FC if I want to shorten the DTR and still get up into the 430–435°F range in a timely way.
So I would not be afraid to try it. You will usually see the curve swing upward, but in my experience that is harmless as long as you also increase the fan to keep it under control.
I’ve had very good success using that combination.
After looking hard at the roast curve, I elected to take a chance on AI and so I asked Copilot using this query: “timestamped RoasTime profile for a dark roast ending at 435 degrees Fahrenheit on a Aillio Bullet R2 Pro that keeps the dtr less than 26% using 8 ounces of Bali Blue Moon Organic wet hulled beans”. Well, Copilot came up with a profile; but it didn’t produce the kind of curve I had hoped for. Still, ending at 435F, even with a terrible looking curve, gave me a tasty cup of coffee. I will say that the description Copilot gave of the way the coffee should taste with that profile was pretty well spot-on. I have linked to it below. One thing I did differently than Copilot suggested was to preheat to 419F instead of 570F. Copilot said preheat to 570 then wait until the IBTS reads 420 to charge the beans. My Bullet doesn’t work that way, so I figured starting at 419 would have to suffice.
Thanks for the update and for sharing the latest curve!
Glad the coffee still came out tasting very good at 435.6 °F even with the curve not looking ideal. These wet-hulled Balis are pretty forgiving.
Yes, the FC came way too soon at 7:30 @ only 380 °F — that’s significantly earlier than the sweet spot for this bean. You’re spot-on: the preheat of 419 °F was too high, which accelerated the pre-FC phases and pushed first crack early. That’s exactly why the development phase ended up so long (4:38) and the DTR climbed to 38 %.
Since your previous roasts at 347 °F preheat gave you a much later (and better-timed) FC, I’d suggest going straight back to that 347 °F preheat next time. Delaying FC this way also lengthens the Maillard phase, which is important for flavor development and really helps bring out the rich chocolate and earthy notes this bean loves.
Once FC lands closer to the expected 9:30–10:30 window, give it a solid P8 boost right at first crack to counter the big endothermic reaction (the sharp RoR drop when the beans absorb heat and release steam/CO₂). That should bring the DTR right into the target 25–28 % range while keeping the clean light-oil Vienna finish.
Having done lighter roasts before now, I’ve been wondering how to approach dry, and Maillard and then have enough energy to get to 435 in short order. I’m inclined to agree that going back down to 347 is a good place to start. If I can hit FC at 9:30, that would allow me to use up to 3 minutes in the development phase without going past 25%. So, the plan (loosely) would be Yellow at 5:30, FC @ 9:30, and EOR @ 12:30 with an end temp of 435F. If I can get close to those times I’ll be happy. I’m guessing F2 until 5:30, F3 until 9:30, and then F4 would be reasonable for the fan. I’ve got my work cut out for me, but with 3-1/2 pounds of beans left, I should be able to nail it sooner rather than later. Incidentally, I have read that a roast that doesn’t seem to change much with days of rest may indicate a fault related to flattening ROR, which based on my last curve is probably what I’m seeing.
I think I’m getting the hang of roasting dark. I just completed another roast of the Bali’s and am close to where I want to be. I used a preheat of 329F (18F lower than my normal preheat) and went with P8 early for about 2 minutes before dropping to P7. This got me to the end of dry in a little over 4 minutes and to first crack at the 7:15 mark. My momentum was carrying good at this point, but I got overly anxious and cut power back to P6. I ended up at about 30% DTR. I believe if I had stayed at P7 until around 410F I would have a better DTR. Still, I am close now. My thanks for the suggestions of power and fan speeds which have both helped me immensely. The Bullet offers so many ways of getting where you are headed, and it’s easy to miss some of them.
I know this is an older thread, but our discussion here was actually a good example of the problem I eventually set out to solve.
Since then, I’ve developed a web app called RoastRecipeAdvisor for Aillio Bullet owners. Rather than asking a general-purpose AI to invent a roast profile from a prompt, it works from your actual roast history, bean, batch weight, recipe, curve, events, and prior results. It then suggests specific adjustments for the next roast based on what actually happened on your Bullet.
Your Bali Blue Moon progression would have been an ideal use case: import the completed roasts, compare the different preheats and power/fan decisions, and use each result to refine the next attempt while keeping the desired darker finish and development target in view.
You can try it here: RoastRecipeAdvisor
I’d be especially interested in what you think, since you worked through this process manually and also tried Copilot along the way.
I saw your link on another post and began setting up an account. Yes, sending my roasts in for examination would likely help and since I still have enough beans left for several more roasts this might be a way to hone in on the right profile. I did some hopping around on those roasts early on rather than being methodical in my approach and it showed. However, there are a few of the more recent roasts that I could use as data for an examination. When I tried Copilot I gave it what I thought was a very detailed write up on what I wanted. I specified the R2 Pro, the beans, the batch size, relative yellow, dry and development times and ending temperature. Copilot suggested a preheat of 570F then dropping down to 421F before charging, along with P8 to start. Well, I guess you could do that by getting up to preheat and then lower the PH temp before charging, but I haven’t tried it. I simply preheated up to 419F and found out that with 8 ounces of beans I had a very short drying phase of 2-1/2 minutes and a fishbowl curve. The beans had a burned taste to them that never really mellowed out. I’ve had pretty good results preheating to 347F on all the beans I’ve tried, but then again with the right power levels I might find success with a higher preheat. I will finish setting up my account and then import my Bali roasts to see what recommendations are made. I appreciate your making this available!
@nomad, I’m glad you decided to finish setting up an account and try the Bali roasts.
That 570°F preheat recommendation strikes me as extremely high for an 8-ounce batch on an R2 Pro. There may have been some reasoning behind heating the roaster that high and then lowering the preheat setting before charge, but I would not be comfortable recommending that from the written information alone. Your experience at 419°F also shows why a suggested number needs to be considered in the context of the complete roast rather than by itself.
You can import the recent Bali roasts and see what information RoastRecipeAdvisor can recover from them. The more methodical roasts—especially ones that followed a saved RoasTime recipe—will probably be the most useful for comparison.
The important thing for the next roast is to complete the full setup before roasting. For the app to give a valid recommendation, it needs the Bean and recipe context, baseline preheat and batch weight, current ambient temperature, and the batch weight you actually plan to roast.
Run Pre-Roast Setup before preheating the Bullet. That creates a saved snapshot of the intended Bean, recipe, ambient temperature, batch weight, and calculated setup. After the roast is synced, the app can examine what actually happened against that original plan instead of trying to reconstruct the setup afterward.
Once you have finished the account setup, imported the recipe, prepared the Bali Bean in Bean Inventory, and run Pre-Roast Setup for the next batch, you will have a much cleaner starting point for making one controlled change at a time.
Please let me know where you get stuck during setup or what the Dashboard says is still missing. I’m interested to see what you find as you work through the remaining Bali.
Carl
