I’ve been using the Analyzer and would like to be able to print a profile to a hard copy printer, or to an image file to enable me to review more closely and markup the print with notes. I tried to paste the embedded code into a PowerPoint, as you would an iFrame video snippet, and that didn’t work. I also tried to print screen and that didn’t work either. Has anyone figured this out?
I’m on Win10 and use the snipping tool (the “window” key + shift + S) to do what you’re trying to do, then just paste the image into a Word doc to print. I do this all the time ![]()
Thanks for that! Another copy tool.
You can also do a Screenshot with “window” + Fn + Prt Scr. That saves a sequentially numbered .png file in the Pictures\Screenshots folder in Windows Explorer (I’m on Win11; Win10 worked the same). Like the snipping tool, a screenshot excludes the mouse cursor.
Edit- I experimented with the Windows snipping tool vs. Screenshots. The snipping tool beats having to go to Paint to edit to a useable image. I think screenshots are going to go away for me. Thanks Lisa!
You’re welcome Bruce ![]()
Hey @ray_trayno,
Would you want to include both the graph and table or just the table? I can probably work on making this easier for all with the ctrl/cmd + p command.
Best regards,
Derrick
I went ahead and played around with this for a bit. The options are limited but if you use these settings when viewing the roast analyzer, you should be able to get a workable printout of the analyzer:
Settings
Output
Let me know if there’s anything in particular I can work on here to make this more useful. Happy to extend the analyzer more if you all have some suggestions.
Best regards,
Derrick
@derrxb thank you for so quickly jumping in on this; I followed your guidance and was successful at saving a PDF; this should suffice for my needs. I don’t have any suggestions for making any feature changes to the Analyzer at this time.
