I would like to suggest a longer preheating at lower temperatures. I am roasting outside at 1C and the first roast is always spoilt.
Thank you
Ernst
Thank you
Ernst
This is extremely cold and could lead to even bigger problems such as excessive condensation.
Of cause can you always add some more minutes after the roaster indicates being ready for charging, however these low temperatures are certainly a challenge IMHO.
As far as I know, the suggested roasting temperature is between 10C & 30C. As and when it dips below 10C, a space heater facing the roaster helps while roasting.
