Between Batch Protocol
I’m curious if other roasters have found a BBP that work well for them on the bullet and what it is specifically. I’m currently in Scott Rao’s online course and his BBP for gas machines is:
  1. Turn off Gas
  2. Drop Batch
  3. 3:30-4:30 down to bottoming temp
  4. Low gas up to charge temp in no less than 60 and no more than 90 seconds
  5. Charge beans
I can’t seem to accomplish this due to the programming in the bullet wanting the drum to soak longer than 90 seconds before switching into “charge” mode and the fact that the drum heats up very quickly (induction process effect??)
The Bullet is waiting for pre-conditions to be met, principally it’s looking for thermal equilibrium at a user-selected temperature… your Pre-heat setting. Additionally B-Temp must be stable for 1 min after the drum has reached the target temp. The f/w routine is not looking for a specific B-Temp- just stable for a minute after the other conditions have been met.
The Bullet thermal mass is very low compared to a gas fired roaster so it retains less heat from the preceding roast. Being a low drum-mass roaster it’s also very response to power, fan and drum speed changes.
Thanks Bruce! In light of this, do you have a BBP recommendation. I do notice a significant difference (+/- 20-30 seconds of roast time and a 10 degree difference in turning point) in roasting with a warm up process but can’t seem to nail down a BBP for consistency?
Sorry… what’s “BBP” stand for?
Between Batch Protocol. It’s what you do between batches to keep consistency
Just go to Preheat and let the roaster take care of it.
I use B-Temp to decide when to start the next batch (and that can take over 30-40 min for the 1st batch; patience is needed!). B-Temp will creep up slowly after the first batch. For my 550 gm batch size and 410° preheat temp I wait for B-Temp to recover to about 302°-305°. By the 3rd batch it takes hardly any time at all so I have to be quick getting the cooled beans winnowed then bagged before it’s time to Charge the next batch. By the 4th or 5th batch I have to wait for B-Temp to drop to my charging B-Temp.
Since the B-Temp probe is mounted on the face plate it’s a good indicator of how much heat has been recovered since the preceding roast. Imo the secret is in being consistent; it’s more important than the pre-conditions you choose… without consistency it’s a crap shoot.
But of course there are other views, so YMMV.
Edit- I’m doing a heat-soak roast which starts at lower power settings then starts increasing. I didn’t understand what @quartzglen was doing initially and my profile is too slow in applying heat for what he suggested. But it seems to work for my dark roasts so I keep on keeping on.
Also I Preheat to 419° on the first batch then 410° on 2nd & later batches.
Keep in mind Rao writes primarily with a large gas powered commercial roaster in mind. His protocol is aiming to replicate the total system heat so that the roaster is in an identical spot, thermally, at the beginning of each batch.
The bullet has an algorithm to replicate this for the IBTS to try and match conditions, but we have an additional data point - the BT temp. Like Bruce mentioned, if both of these temps don’t match at the beginning of each batch, your roasts are going to start differently.
Typically it’s hardest to nail down the first batches (when the system is at its coolest) I’ll also typically preheat at least +10f hotter than my target temp for 20-30 minutes and then let the roaster cool into my target charge temp.
what I experienced is that it is difficult to follow the same roast profile in 3 subsequent roasts. The first roast always takes longer, for teh second and the subsequent roasts the BT & IBTS will allways reach the set points in a shorter time, so that I can’t do identical roasts with the once set profile with interfering in the heat management. Any recommendations?
I find that even with long preheating (25 minutes?) that the first roast always starts at a lower BT than the same PH temp would after another roast.
One simple method that I’ve used to try to counteract this is to apply an extra level of power for about one minute during the beginning of the dry phase.
For reference, that’s usually a 550g batch, 428F preheat, so I’m usually starting between P7 and P9 depending on the bean, and have room to go up a level temporarily.
Giving the roast an extra level for a minute usually brings temps and times back in line by the end of the dry phase, and the rest of the roast proceeds like it would if it were not the first batch of the day.
Between roasts, I also watch the BT. In the conditions described above, I usually look for a BT of about 325F before charging the next batch, and I’ve found this leads to consistent results from the second batch on. The key thing though isn’t that particular temp, it’s consistency.
