Hi All
I’m relatively new to the Bullet with only 17 Roasts in but verry happy with the results so far and with the upgrade it offers to my old Hottop with Artisan.
I was also very happy with the new Blend feature as i have older recipies with green blending.
But today when i was checking my stock i did see that it doesn’t change the stock ammount when you roast a blend. is this by design or is this a bug?
Help would be apreciated
Hey, that sounds like a bug. We will open a ticket in our backlog and check into this.
Wow thats fast, thank you. Aldo a nice to have would be to define the blends by percentage rather than weigt. So that you don’t need to make two blends for lets say 500g an 1kg.
Yes you don’t need the fature.
But as i described i blend pre roast an than it is great to have this feature.
Another thing that i noticed but forgott to mention is that you can not select the blend in roast time when you put in the roast data. only after the roast is done you can put it in in the roast overview with all your past roasts.
