I wanted to edit and rate my roast via the Roast World website. I had a roast with no First Crack End (00:00) and an error that “End time cannot be before the start time” came up. This prevented me from rating the roast and doing an “Update”.
I was able to rate my roast via Roast Time v 3.17 editing. The change showed up when I went back to the Roast World website. The edit window on the website only allows me to read the data.
-HK
Same problem here every time I want to edit something post roast.
It seems like the “1st Crack end” option has been made a mandatory box to check.
Doesn’t make any sense and is quite annoying if you ask me.
This is a bug and we are working on fixing it. Thanks for letting us know.
Hi, this has been fixed. If you still can’t update roasts, try reloading your page. ![]()
Thank you for the quick turn around. No issues now.
