Bullet R1 red blinking mode (not IBTS temp)
Hi all,
Got the following error logs which result in power down at 4-5 mins into roast.
Device Model - / Board undefined / Serial / Firmware
It is high ambient temperature, but the other Bullet R1 sitting next to it is fine.
Any help appreciated.
Error 32769
Error 35 - Coil fan 2 blocked
Error 31 - Exhaust fan blocked
Hi @mp_bradford,
Thanks for the post. These error codes suggest that your Chaff Collector might have been seated incorrectly. Could you try reseating the Chaff Collector and see if the issue goes away? You should hear a gentle click while seeing the Pull tab bounce a bit outward when the Microswitch is properly engaged.
Best regards,
Kevin
