Bullet starting roast before loading the beans
Hi I’m having a issue where right after my roaster is charged it starts the roast before I can even load my beans. Did anyone have this problem or no why this is happening?
Thanks
Nate
Bullet uses temperature drop as a trigger so if you have any ducting on the exhaust that has a fan and is pulling air through faster that might do it…
Ok. Right now I’m using a box fan in the window until I vent it through duct work… Maybe the bullet is to close to fan. I Will try and move it away a little bit and see what happens.
Thanks @stuartmcknight
I moved bullet away from the fan a little bit and that seemed to work. Thanks again @stuartmcknight
