I have Version 4.9.0 of Roastime installed on a Windows 11 machine. I can see the Bullet in the device manager with the yellow caution flag. I have tried to use the USB drivers software update in the settings as well as the Zagdig tool. The Zagdig tool returns an error that the install has failed. I have deleted everything and reinstalled with no success. Any ideas?
Do you still see a yellow flag after restarting your computer? I truthfully have not seen this behavior before - but I believe the yellow flag indicates or a driver or hardware issue. It is interesting that you have yellow flags on almost all your devices. Are these plugged in through some sort of proxy/hub?
This is a standalone laptop only plugged into the Bullet. I deleted all the other instances and now I just have the two flags when the bullet is plugged in.
I have the same issue, my USB driver disappeared in the middle of a roasting session. Were you able to resolve this?
