Putting you adaptor on its first run today! Really like it is just a magnet
Is it PVC material?
Thank you.
I’m not sure what you’re asking? My model is made out of ABS plastic, if that’s what you mean. PVC is not a material you can 3d print.
Oh yes It’s ABS.
Thank you so much.
Does this stand up with that cooling tray fan outer high temp?
I’ve not had an issue so far, and I’ve probably put 20-30 lbs through it so far. Warping would be pretty unlikely too even if it did soften slightly, as there’s basically no load on the parts that would get hot. The parts the magnets sit in should stay cool, since they’re pretty far away from the actual path of hot air.
