Chaff collector not mounted indicator no longer working
Hello - rather than the fan powering down and alert being voiced now when I remove the chaff collector the R2 Pro no longer appears to be detecting when it is removed and so the fan is spooling up, presumably in response to the change in air pressure.
Not sure if this is something to be concerned about and what the underlying diagnostic might be?
OK - this seems to be resolved. Seems like the micro switch might have just been depressed in and sticking so I vacuumed around it and ran some manual tests and seems to be ok now!
