Hello, I recently got a barely used Aillio Bullet R1 V2. When I first connected to roast time it wouldnt connect to the bullet. Eventually I installed the the ZAdiag method and was able to get it to connect. Now every time I start Roastime it doesnt connect and I have to delete the deps folder. When I start it again it updates, so I have to delete deps again.
I originally tried installing everything with updated versions as it recommended but after the manual install I think I am behind. What is the proper course of action? I am worried if I update things I might get stuck. Right now I can make it work but it is a bit annoying. Is there a certain upgrade path I should follow, or any versions I should avoid? I heard some newer versions had issues.
Currently the Aillio bullet shows up in device manager under USB Devices
Software versions
Client 1.198.8
Proxy 1.67.1
Communication Service 3.9.11
firmware 605
