The cooling fan filter is getting sucked into the cooling fan - and thus getting chewed up - when I drop the bean at the end of the roast. This is a new unit, and after the seasoning roasts, it’s happened on my last two roast. I’ve roasted a total of four roasts so far.
Is anyone else having this issue? If so, what’s the resolution?
I have a V2 and I did install a guard (as shown in the post #3 of that thread with the Amazon link) to maintain some separation between the filter and the fan to be safe.
Had that happen as well. You’re not alone I 3D printed a screen now to solve that issue. IMO, Aillio should provide a simple plastic housing for the filter that would prevent this issue for existing owners. In the least regard, provide one as a low-cost solution, while including it with all future Bullets. When it happened to me, it was hideous (the sound) and I was not sure what happened at first and the beans that I took into 2C, sat there overheating in the tray. I pulled the cooling tray out to hand vac it from the bottom, but that’s when I saw the filter had completely jammed / stopped the fan. Since I 3D printed the Aillio .stl for the cooling tray exhaust and had ducking connected, I just pulled the filter out entirely to cool and complete the roast. Not cool ← pun regretfully intended.
And that’s with me taking care to clean the filter each roast and flip it around from time to time, making sure it’s seated well. I probably only had 30 roasts on that filter. Had it been in a frame (kinda like a lawn mower filter), that would have never happened.
Hey Blacklabs. Just wanted to let you know that I just installed the fan grill that you posted. Fits and works perfectly. Quick and inexpensive fix! Thanks!
Gutter screen. Cut to 3 1/4 x 4 1/4, with tiny diagonal at bottom. Fits perfectly into slot in front of fan. Use floor vent filter cut to size. I usually double it . Just a few bucks and you have enough screen for a dozen, though I think the one will last indefinitely.
