Dev Time and True Dev in analyzer - weird values [fixed]
Hi,
I’m comparing two roasts but can’t make sense of the Dev Time and True Dev values. For example this roast Log in | Roast.World
The time after first crack was 1:00 and the temp delta was 6.7 IBTS and 9ish on BT. In the analyzer the Dev time shows as -423s which is roughly 7 minutes (ignoring the “-” sign) which is the time to FC (so almost like the inverse dev time).
True Dev shows 3.37 C and -428.5s which makes no sense to me.
Does anyone have pointers?
Hey @mosei,
I’ve added this to our backlog to get it looked at. I’ll respond here when I get an update.
Derrick
I got this issue after changing the X,Y values in chart defaults. the analyzer offsets the values somehow!
How do you change that?
For now it has to be done in RoasTime as they both share the same settings. You can access this in the Roast Config section of your RoasTime settings.
Derrick
Checked. They’re all 0 and have always been that.
@derrxb Wonder if you have a chance to look into this.
We have a ticket for this and working on it.
Hey @mosei,
Letting you know this has been fixed.
Derrick
