It would be super helpful if I could simply reorder steps in my Recipe by dragging and dropping the steps. Right now, if I build it in the wrong order, I have to start over.
The issue is that the Recipe feature orders steps by Time and it sounds like you may be using Temp to manage the roast… ?? If you are, and until they make a change to allow re-ordering Recipe steps, I use the mandatory Time test to maintain order. Using mm:ss I increment ss (seconds) by 1 in order to force a sort in my intended sequence. I believe/hope (?) that it’s an unnecessary conditional step and that the Recipe will complete in proper order without regard to my visual sort. But it sure makes life easier when creating the Recipe to have the order clear.
