Hi when I go to setting in Roastime and Software version It has (install drivers) and when I click on that the driver download and install popup appears asking to choose the download location. what is the location for this driver?
Thanks.
Steve.
Try look here Rost.Time3 and new Feb 2021 Bullet? no driver (solved)
Aillio team works fast <3
Main site was down right but, I god the link here in some magic way
Direct link to RoasTime-3.1.7-x64.Setup.exe (win64) https://files.aillio.com/download/win_64
Direct link to RoasTime-3.1.7-ia32.Setup.exe (win32) https://files.aillio.com/download/win_32
I had a similar problem. I created a folder and tried to put the drives in there but nothing would happen.
Then one time I didn’t select any folder and just cliked the button “select folder”, and it downloaded the drivers no problem.
Hope that helps
Well I think I’ve now tried every thing to load the new drivers and nothing has worked. Starting to wonder if the laptop needs replacing ( although all other stuff works fine, all the other Aillio upgrades worked fine). I just want to roast not bugger about with computers, I do enough of that 8 hours a day at work.
Sorry had to vent, I hate brick walls.
Steve.
Did you try Madsen’s post about manually setting the WINUSB driver here:
