Drum constantly making a grinding sound
I performed a deep clean, and after reassembling it, the drum produces a grinding sound in all phases. It gets louder on the roast cycle
Check page 27 of the official manual:
And I would also check if the screw that holds the handle of ejection door isn’t sticking out and hitting the agitator blades.
Drum issues - door opening & clunking sounds - Aillio News & Updates - Roast World Community
I had the same issue. This what I did… When I took the face plate off I was not aware of the shims behind the bearing, in fact there were 2 of them. I found the shims, replaced them on the shaft and the roaster has been happy… Hope this helps.
Thanks everyone. I changed the shims and it’s fixed now
