ErC 736 Upon start up
New R1 owner here, and I plugged in the machine today to roast, and I got the code 736 after the start up cycle. Additionally the cooling fan for the beans and the roaster would not turn off. Ive only done 15ish batches on this bad boy and I have done all the maintenance stated in the manual. Any thoughts? I’ve reached out to Aillio for help.
Hi Zach,
Did you do any maintenance before this happened?
Any chance you could upload a video of the startup sequence and connect RoasTime and copy the logs from the info panel?
Thanks for the quick response, I emptied the chaff collector and returned it to its proper position as well as cleaned off the filter in the cooling tray. I essentially did everything the manual said in the “after every roast session” section.
Im not entirely sure if i can upload the .mov file here, is there another way to upload it?
Here are the logs, I am not entirely sure which ones are useful, but I copied and pasted it all.
[{“code”:28675,“value”:1},{“code”:32769,“value”:0},{“code”:32769,“value”:13698},{“code”:29458,“value”:1904},{“code”:29460,“value”:925},{“code”:29468,“value”:140},{“code”:29467,“value”:95},{“code”:29448,“value”:651},{“code”:28674,“value”:3},{“code”:28688,“value”:14700},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:32769,“value”:13698},{“code”:17,“value”:0},{“code”:38,“value”:75},{“code”:18,“value”:0},{“code”:19,“value”:0},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:130,“value”:6},{“code”:28674,“value”:0},{“code”:28688,“value”:17370},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:131,“value”:256},{“code”:32769,“value”:0},{“code”:32782,“value”:0},{“code”:32789,“value”:0},{“code”:32769,“value”:13642},{“code”:131,“value”:256},{“code”:32769,“value”:13642},{“code”:32783,“value”:0},{“code”:32791,“value”:0},{“code”:32785,“value”:0},{“code”:131,“value”:256},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:131,“value”:256},{“code”:131,“value”:256},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:131,“value”:256},{“code”:131,“value”:256},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:131,“value”:256},{“code”:131,“value”:256},{“code”:31,“value”:0},{“code”:131,“value”:256},{“code”:31,“value”:0},{“code”:131,“value”:256},{“code”:31,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:19,“value”:0},{“code”:130,“value”:6},{“code”:28674,“value”:1},{“code”:28688,“value”:19800},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:19,“value”:0},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:130,“value”:6},{“code”:28674,“value”:0},{“code”:28688,“value”:18390},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:131,“value”:256},{“code”:32769,“value”:0},{“code”:32782,“value”:0},{“code”:32789,“value”:0},{“code”:32769,“value”:10702},{“code”:131,“value”:256},{“code”:32769,“value”:10702},{“code”:32783,“value”:0},{“code”:131,“value”:256},{“code”:32783,“value”:0},{“code”:32791,“value”:0},{“code”:32785,“value”:0},{“code”:131,“value”:256},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:19,“value”:0},{“code”:130,“value”:6},{“code”:28674,“value”:1},{“code”:28688,“value”:19860},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:19,“value”:0},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:130,“value”:6},{“code”:28674,“value”:0},{“code”:28688,“value”:19920},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:131,“value”:256},{“code”:32769,“value”:0},{“code”:32782,“value”:0},{“code”:32789,“value”:0},{“code”:32769,“value”:14014},{“code”:131,“value”:256},{“code”:32769,“value”:14014},{“code”:32783,“value”:0},{“code”:131,“value”:256},{“code”:32783,“value”:0},{“code”:32791,“value”:0},{“code”:32785,“value”:0},{“code”:131,“value”:256},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:19,“value”:0},{“code”:130,“value”:6},{“code”:28674,“value”:1},{“code”:28688,“value”:20010},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:19,“value”:0},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:130,“value”:6},{“code”:28674,“value”:0},{“code”:28688,“value”:18060},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:131,“value”:256},{“code”:32769,“value”:0},{“code”:32782,“value”:0},{“code”:32789,“value”:0},{“code”:32769,“value”:7928},{“code”:131,“value”:256},{“code”:32769,“value”:7928},{“code”:32783,“value”:0},{“code”:131,“value”:256},{“code”:32783,“value”:0},{“code”:32791,“value”:0},{“code”:32785,“value”:0},{“code”:131,“value”:256},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:19,“value”:0},{“code”:130,“value”:6},{“code”:28674,“value”:1},{“code”:28688,“value”:19230},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:19,“value”:0},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:10,“value”:4},{“code”:2,“value”:260},{“code”:130,“value”:6},{“code”:28674,“value”:0},{“code”:28688,“value”:17370},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:131,“value”:256},{“code”:32769,“value”:0},{“code”:32782,“value”:0},{“code”:32789,“value”:0},{“code”:32769,“value”:5065},{“code”:131,“value”:256},{“code”:32769,“value”:5065},{“code”:32783,“value”:0},{“code”:131,“value”:256},{“code”:32783,“value”:0},{“code”:32791,“value”:0},{“code”:32785,“value”:0},{“code”:131,“value”:256},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:19,“value”:0},{“code”:130,“value”:6},{“code”:28674,“value”:1},{“code”:28688,“value”:17040},{“code”:28672,“value”:57671},{“code”:28673,“value”:40564},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0},{“code”:1,“value”:4},{“code”:2,“value”:260},{“code”:33,“value”:0},{“code”:35,“value”:0},{“code”:38,“value”:0}]
