please help. It just happened after cleaning - Ive checked all connections - dunno what to do
Err 0001
No communication with the induction module. Happens at startup. Most likely because a connector is loose on the control board. If you recently took off the front plate you might accidentally
have pulled out the connector.
Remove the cover plate on the control board. Remove the 4 black screws securing the Pcb module. Carefully pull out the module and check that all connectors are in place.
Reassemble.
@squaretilldeath welcome! try ChatGPT - Allio Bullet Coffee Pro for quick answers to common questions
