Error status: Not a route error
User details/reproduction:
Hey if this is regarding creating a support ticket in roast.world, it should be resolved now.
2568-03-10 23:03:24> Program: Starting Squirrel Updater: --install .
2568-03-10 23:03:24> Program: Starting install, writing to C:\Users\hobbyz\AppData\Local\SquirrelTemp
2568-03-10 23:03:24> Program: About to install to: C:\Users\hobbyz\AppData\Local\RoasTime
2568-03-10 23:03:24> CheckForUpdateImpl: Couldn’t write out staging user ID, this user probably shouldn’t get beta anything: System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\hobbyz\AppData\Local\RoasTime\packages.betaId’.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at System.IO.StreamWriter…ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
at System.IO.File.WriteAllText(String path, String contents, Encoding encoding)
at Squirrel.UpdateManager.CheckForUpdateImpl.getOrCreateStagedUserId()
2568-03-10 23:03:24> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\hobbyz\AppData\Local\RoasTime\packages\RELEASES’.
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Squirrel.Utility.LoadLocalReleases(String localReleaseFile)
at Squirrel.UpdateManager.CheckForUpdateImpl.d__2.MoveNext()
2568-03-10 23:03:24> CheckForUpdateImpl: Reading RELEASES file from C:\Users\hobbyz\AppData\Local\SquirrelTemp
2568-03-10 23:03:24> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2568-03-10 23:03:25> ApplyReleasesImpl: Writing files to app directory: C:\Users\hobbyz\AppData\Local\RoasTime\app-4.10.3
2568-03-10 23:03:28> LogHost: Rigging execution stub for RoasTime_ExecutionStub.exe to C:\Users\hobbyz\AppData\Local\RoasTime\RoasTime.exe
2568-03-10 23:03:31> ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\hobbyz\AppData\Local\RoasTime\app-4.10.3\RoasTime.exe]
2568-03-10 23:03:31> ApplyReleasesImpl: Couldn’t run Squirrel hook, continuing: C:\Users\hobbyz\AppData\Local\RoasTime\app-4.10.3\RoasTime.exe: System.ComponentModel.Win32Exception (0x80004005): The specified executable is not a valid application for this OS platform.
at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at Squirrel.Utility.d__11.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Squirrel.UpdateManager.ApplyReleasesImpl.<>c__DisplayClass10_0.<b__0>d.MoveNext()
2568-03-10 23:03:31> IEnableLogger: Failed to invoke post-install: System.ComponentModel.Win32Exception (0x80004005): The specified executable is not a valid application for this OS platform.
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at Squirrel.UpdateManager.ApplyReleasesImpl.<>c.b__10_6(ProcessStartInfo info)
at Squirrel.EnumerableExtensions.ForEach[TSource](IEnumerable1 source, Action1 onNext)
at Squirrel.UpdateManager.ApplyReleasesImpl.d__10.MoveNext()
at Squirrel.Utility.d__42.MoveNext()
2568-03-10 23:03:31> Unhandled exception: System.AggregateException: One or more errors occurred. —> System.ComponentModel.Win32Exception: The specified executable is not a valid application for this OS platform.
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
at Squirrel.UpdateManager.ApplyReleasesImpl.d__2.MoveNext()
at Squirrel.UpdateManager.d__10.MoveNext()
at Squirrel.Update.Program.d__4.MoveNext()
— End of inner exception stack trace —
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at System.Threading.Tasks.Task.Wait()
at Squirrel.Update.Program.executeCommandLine(String args)
at Squirrel.Update.Program.main(String args)
—> (Inner Exception #0) System.ComponentModel.Win32Exception (0x80004005): The specified executable is not a valid application for this OS platform.
at Squirrel.Update.Program.d__4.MoveNext()<—
2568-03-10 23:04:20> Program: Starting Squirrel Updater: --install .
2568-03-10 23:04:20> Program: Starting install, writing to C:\Users\hobbyz\AppData\Local\SquirrelTemp
2568-03-10 23:04:20> Program: About to install to: C:\Users\hobbyz\AppData\Local\RoasTime
2568-03-10 23:04:20> Program: Install path C:\Users\hobbyz\AppData\Local\RoasTime already exists, burning it to the ground
2568-03-10 23:04:21> CheckForUpdateImpl: Couldn’t write out staging user ID, this user probably shouldn’t get beta anything: System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\hobbyz\AppData\Local\RoasTime\packages.betaId’.
2568-03-10 23:04:21> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\hobbyz\AppData\Local\RoasTime\packages\RELEASES’.
2568-03-10 23:04:21> CheckForUpdateImpl: Reading RELEASES file from C:\Users\hobbyz\AppData\Local\SquirrelTemp
2568-03-10 23:04:21> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2568-03-10 23:04:22> ApplyReleasesImpl: Writing files to app directory: C:\Users\hobbyz\AppData\Local\RoasTime\app-4.10.3
2568-03-10 23:04:25> LogHost: Rigging execution stub for RoasTime_ExecutionStub.exe to C:\Users\hobbyz\AppData\Local\RoasTime\RoasTime.exe
2568-03-10 23:04:29> ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\hobbyz\AppData\Local\RoasTime\app-4.10.3\RoasTime.exe]
2568-03-10 23:04:29> ApplyReleasesImpl: Couldn’t run Squirrel hook, continuing: C:\Users\hobbyz\AppData\Local\RoasTime\app-4.10.3\RoasTime.exe: System.ComponentModel.Win32Exception (0x80004005): The specified executable is not a valid application for this OS platform.
2568-03-10 23:04:29> IEnableLogger: Failed to invoke post-install: System.ComponentModel.Win32Exception (0x80004005): The specified executable is not a valid application for this OS platform.
2568-03-10 23:04:29> Unhandled exception: System.AggregateException: One or more errors occurred. —> System.ComponentModel.Win32Exception: The specified executable is not a valid application for this OS platform.
What version of windows are you trying to install this on?
And is it 32bit or 64bit windows?
RoasTime 4 is only supported on 64bit windows.
The key log in that error there is this:
As @jacob mentioned, we only support 64 bit.
