Estimated Warm Up Time?
I have searched and failed, but maybe some else knows this already.
I would love to have an estimated count down timer for when the roaster will meet its warm up temperature and is ready for CHARGE.
Usually I kick off a roasting day by getting my first batch programmed and warmed up then I quickly pull beans/labels/etc. I seem to always be caught off guard when the roaster says CHARGE, and I figured surely there is a way for us to embed a new feature that tells us how many minutes we have remaining til it’s preheated.
I utilize the Roastime software mostly, and don’t mess with the roaster LCD controls often, maybe there is a feature on there outside of the temp showing a slow increase?
I find at 500g to usually 464F it hits charge at about 23 min from preheat start. I am sure that varies for all sorts of things though.
Well, I think that would be hard to implement, as every PH temp would need to be set. Also, countdown timer assumes there’s a fixed time when the roaster will reach the desired temp, but this varies depending on time of year and in room conditions, unless you have an extremely well controlled and fixed temperature, humidity and air flow in the space where the roaster is. And you should take into account that “charge” on the first roast of the day does not mean charge. It usually reaches the temp needed to start the roast approximately 10 minutes after it says charge on the first roast of the day. So, the countdown timer would also have huge differences between the first and other roasts.
Based on someone else’s advice, I wait on first roast until the bean temperature stabilizes (flattens out) which is an indication of the front plate temperature being stabilized. Regardless of preheat level from 464 to 500 it seems to consistently take 20-25 minutes. I roast in an indoor environment at 70-75 degrees.
++ on ~25 minutes on an R2 ventilated with an air gap. I usually use IBTS to set the preheat temp, but wait for BT to be about 150-160F less than IBTS. So, for example, for a 590F preheat, 435F BT.
In my experience this is as much about repeatability as anything; I try to ensure that the temps have returned to that 150-160F gap between batches before charging the next load of beans.
