I just updated my firmware (not sure if this was a coincidence) and having a problem upon start up. The exhaust fan is running but the front display is blank and doesnt light up at all.
Hey - this sounds like what is happening to me - no lights on the control board, but unit powers up, but exhaust fan and PCB board fan go on ‘full’ - computer does not recognize USB - does this sound similar? can you clearify the ‘connect GND & SDA’ piece - I have found the marked holes - do I just stuff a paperclip in? Thanks so much for any help!
Aillio support are you able to confirm this is a safe and reasonable fix?
Best go to the Aillio site. Under Support find the .pdf for forcing the Bullet to boot mode. You are doing this to allow f/w to be reloaded… the thought posted here is that the f/w is corrupted. It’s best if you have a helper to deal with power while you hold the jumper in place and try to not short something unintentionally.
Ps- points out the need for a power switch. I have an external power control box for this situation.
I’m having this issue and wanted to make sure this is the solution for the Bullet R1 v2. I’ve checked on Aillio’s site but can’t find the pdf so I contacted support and waiting for a reply.
The second reply above has a very close duplication of the “cold boot” instructions.
I would add that after the f/w install the process requires disconnecting the USB cable and cycling the power to the Bullet. But a quick on/off isn’t going to do it… I needed to power off the Bullet, give it a count of say 10, then power up. If it boots up ok, then connect the USB. I have a power distribution box with a breaker for connecting the Bullet to make it easy. There were frequent f/w changes at that time and fussing with that jumper (yeah- a paper clip; still in the tool case) while trying to plug in the Bullet power cord was about one thing more than I could handle safely.
