kafana
                    July 13, 2023,  1:39am
                  1
              I wasn’t sure where to file this, under software or firmware, but here are the steps to reproduce an issue.
Turn on Bullet R1 V2  and preheat
Roast as usual, and sometimes during roast press F1 button to signal first crack to Roastime 4
Roastime 4 will normally register this as FC
Prepare anther roast batch
Preheat and start roasting
Press F1 to signal FC
Roastime 4 doesn’t register  F1 button press
I am not sure if this is issue with Bullet not sending signal to Roastime 4, or RT4 is ignoring subsequent F1 button press actions.
Let me know if you need any additional info.
              I just did a few test runs here and I was not able to re-create this. Does this happen to you every time?
                kafana
                    July 19, 2023,  8:56pm
                  3
              Hi @mcaillio ,
It doesn’t happen every time. Last night I did 4 roasts, and It happen on one only. I will try to record this next time.
                kafana
                    July 20, 2023,  5:14am
                  4
              Hi @mcaillio ,
Finally I was able to reproduce an issue with F1 press to signal FC. It is documented in the zipped mp4 file. Let me know if you need any additional info.
FC-F1-Issue.mp4.zip  (3.0 MB)
              It just happened to me on a first roast. That’s one out of four (just got the Bullet)
              And every time I roast (now). It seemed to start when I started using recepies?
                jacob
                    May 2, 2025,  8:45am
                  7
              The trick is to hold the button down for 1s, then it will register in RT as well.
