Feature Suggestion: Development Percentage as a Trigger
Hello,
I suggest the developers of Roast Time add the ability to use the development percentage as a trigger in recipes. Currently, we have IBTS temperature, bean probe temperature, and time as available triggers to change parameters in recipes. Adding development percentage would be helpful, because Scott Rao, for example, advocates changing heat and fan settings based on development percentage rather than temperature after first crack.
The feature would be easy enough to implement: “If development percentage is X%, then set power or fan to X.”
Thank you for your consideration
Thanks for the suggestion. I will create a ticket to keep track of this request.
