I am currently running firmware v106 and am a bit hesitant to go with v116. I read all the way through the change log and ran across a statement that says if the IBTS isn’t working the Bullet won’t be allowed to preheat. If you have a defective IBTS and you switch to the bean temp sensor, will it refuse to preheat?
Hi @nomad,
We don’t have an option to switch to using any temperature sensors exclusively; the Bullet wouldn’t work properly if either of the sensors fails.
Best regards,
Kevin
Sorry about the confusion. I looked at the preheat settings and saw there was no way to switch sensors there.
