Fix for bean trapped between the Bean Temp Probe and screw
There have been a number of posts about beans getting caught and trapped between the Bean Temp Probe and a screw inside the front cover.
This is a photo that I snagged from another thread by Jimmybulletroaster.
When I was cleaning the inside cover and the IBTS lens, I had a bean trapped there. It happens pretty often.
I took a small piece of stainless steel wire (sometimes called piano wire) and created a loop and loosened the nut for the Bean Temp Probe and put the loop on there and re-tightened the nut.
Now there is no place for the bean to get caught.
I can’t remember where I got the SS Wire. Probably Amazon.
Not sure if I’ll get in trouble recommending this, but replacing the screws with a button head screw (the ones holding the front plate, different size of course) could be a more elegant solution.
I agree. I don’t have any metric button head cap screws in my inventory.
(But I will)
Thanks, Kevin
This is definitely a recommendation for the next Bullet iteration.
This has such an impact on temp readings! I’ve been pushing any beans out between roasts, but should have upgraded to a better part or added wire a long time ago. This is one of the many frustrating things about the Bullet, and Part of why I am contemplating leaving the platform once I can afford it.
Okay, I got some M4 x 8, button head screws from Amazon
and installed them
As Kevin said: “A more elegant solution”
Edit: You will need a 2.5mm Allen wrench to tighten these screws.
Hi all,
A little update: the newer Bullets are now using Buttonhead Screws to secure the Front Plate Hinges.
Best regards,
Kevin
