I reviewed the several topics posted here regarding the best way to hear the two ‘cracks’ events while roasting. I am 67, and recently broke down and worked with a local audiologist and am now sporting some stylish and flatteringly mostly invisible hearing aids. I used to be able to ignore my wife due to hearing loss, but no more. ![]()
When I begin using the aids, and when roasting I noticed that I could no longer hear crack events. My hearing loss is related to nerve damage, and so to correct this, certain frequencies are left alone and others are augmented with the goal of recovering a mostly ‘normal’ hearing experience.
I had to proceed through the 1st roast using the aids, by color. Not that critical a change, but not ideal.
So I did a little research, with the help of ChatGPT I confirmed an assumption that It might be possible to program the aids to favor certain frequencies:
The first crack of coffee typically occurs at a frequency range of about 1,000 to 1,500 Hz, while the second crack is generally around 2,000 to 2,500 Hz. These sounds are often described as popping or cracking noises, similar to popcorn popping.
If you’re looking to enhance your ability to hear these events with your hearing aids, it might be useful to ensure that your audiologist focuses on these frequency ranges during adjustments.
I discussed this with my audiologist this week and she set me up with a program for the aids, that favored these frequency ranges. Bottom line is that they worked amazingly. I do hear all of the other tones in those ranges but I also distinctly hear the crack event (at least the first crack as my roasts this weekend ended below 2nd crack).
Also, to my surprise, I was able to easily call out the end of 1st crack which is something I was never before able to do.
I thought I’d pass this along in case there are others that have programmable hearing aids and might like to check this out and possibly confirm the results.
