Help Please! R2 Pro issue ( sound)
Hi everyone!
I’m very worried. When cooling the R2 Pro I saw a lot of chaff at the top of the roaster and then a very metallic sound. I think something stuck and make the bullet turn off.
I have a video in the exact moment
Any idea ? @jacob @varistaillio ?
https://drive.google.com/file/d/1eOX6QLEM9rm8sdmJhNkao70vgt6mv94U/view?usp=drivesdk[quote=“matiascanzani.I9fA, post:1, topic:20181, full:true”]
Hi everyone!
[/quote]
UPDATE: I found the issue, was a loose screw. But I found another strange sound. Here is the video
Any Idea?
IMG_3464 sounds like you should adjust the drum. Try pushing a little bit on the rotating shaft to see if it then goes away. IMG_3468 sounds normal to me, the gearbox has this sound.
The loose screw was that behind the impeller?
I would take off the impeller and check the screw behind it, then also check that the chaff filter is seated correctly.
Thank you. Was just the loose screw. I’ve roasted new batches without any issue
