Hi everyone! Unfortunately, I am having some issues opening up roasttime. I deleted and redownloaded the latest version twice and restarted my computer and can’t get it to open!
I ended up downloading an older version and it opened. Does anyone know what’s going on? Thanks!
Is it a white screen or doesn’t open at all? Are you upgrading from an older version or is this a first time install?
If you are upgrading from an older version, there was a previous issue that sometimes arises with the shared directories. You will need to manually remove those directories. Are you on Windows or MacOS?
On Windows:
C:\Users"YOUR USER NAME"\AppData\Roaming\RoasTime
C:\Users"YOUR USER NAME"\AppData\Roaming\roast-time
On MacOS:
Library>Application Support> RoasTime
Library>Application Support> roast-time
I generally use the CLI. On windows you could use Powershell to navigate there and remove them with the Remove-Item command. You can also navigate via the FIle Explorer to delete them, but I am not familiar enough with Windows to know how.
@bab has done this in the past, maybe he or someone else has better directions than me.
Insert your own Windows User name in place of mine <…\bab.…> plus the rest of the directories circled in the screenshot, then choose RoasTime and roast-time. Your data is saved on the Aillio servers and should restore when you open RT4 with an internet connection. Those 2 directories will be recreated when you re-install RT4.
