Household outlet
Hello there! Anyone if a “dedicated, grounded circuit” R1V2/ R2 to operate?
I read that The Bullet needs a dedicated electrical circuit with ground (earth). Do not plug other appliances into this circuit.???
Is not safe or recommended to use a household socket outlet ?
It’s OK. You may use any outlet in your home. However, you shouldn’t operate heavy consumers when you’re roasting. Let’s say your house is rated at 3KW 220V, which would mean that you have some space after you run the Bullet for other things, since the Bullet is rated for 7.5-10 amp, and in this scenario you have close to 14 available. If you try to run your washing machine, hair dryer, dishwasher, etc., while you’re roasting, it will be a problem. But even then, you’ll just lose your roast and have no electricity until you flip the circuit breaker back on. And keep in mind that the Bullet only draws this much power on max heat setting.
Thank you @braca19452f9m . I will need to check that because I’m in UK, but not sure really how this works. I’ve move from Argentina that is a quite different.
Yeah, that’s 230V, and I think the lowest amperage you get on a circuit in the UK is 13, so you should be OK. Maybe someone who lives there can confirm this. Still, the recommendation to not run other power hungry appliances while roasting remains.
Thanks! Yep I will …just to be sure and safe! :slight_smile: Happy roasting
