scroll down Apps and Programs list and select RoasTime
click uninstall
try a fresh install. Don’t use your existing installation file, it may be corrupted. If you still have problems then you will have to manual go in and remove any remnant files.
I looked in several subfolders. Usually there is a remnant folder containing the program but I was unable to find one. Not sure which registry values to change without getting into trouble. I think you will need guidance from Aillio. There is a support section on the Aillio website where you can address technical support issues. Leave them a tech support email. The tech support got back to me within a day and they were very helpful.
If your roasts are already synced to Roast.World then you try to remove these:
C:\Users\YourUserName\AppData\Local\aillio-ts
C:\Users\YourUserName\AppData\Roaming\RoasTime
If you are not synced up then you should contact aillio before deleting those folders as you may loose your roasts.
You might need to enable “hidden items” → go to the View tab or View options.
I had this issue. It cleared up by installing a the new 2.0v. But then that caused the inability to see both bean & drum temp on the roaster’s display. Having difficulty believing these sw package not being ready. Great roaster but it’s only as good as the sw…Couldn’t get my Sumatra to dark because of the 428 F drum temp limit prior to 2.0v.
Thank you, that appears to have worked, the software now starts properly. However, my max pre-heat setting is 205, I am unable to increase beyond. Any ideas?
I should mention that the firmware is the beta 448
Also, one other weird thing…which may not matter, when installing the drivers. I use the Force Driver update option. This appears to hang at the step “installing drivers USB\VID_0483&PID_A27E&REV_0200” it never seems to complete
update I removed the drivers via the device manager and was able to update the drivers without hanging, but still unable to get past 205 preheat.
