How To: Self Debugging USB Issues
Hello all,
While we are working on our official docs (it really is being worked on!), I just wanted to write a quick “how to” guide for dealing with USB issues that are somewhat common.
Step 1: Determine if the problem is hardware or software
The first thing we need to do is figure out if you have a hardware or software issue. Every OS has tools available to see if the roaster is seen by your OS. Here are common ones I use:
Windows: The roaster should show in Device Manager as “Aillio LTD Bullet R1 Roaster FS”.
MacOS: Open Terminal and run ioreg -p IOUSB -l -w 0 to list devices. You should see the Bullet
Linux: lsusb from Terminal should show you the Bullet in the list.
If the roaster is plugged in and you do not see it - you have a hardware issue. Try a new cable and if the issue persists, open a ticket at [email protected] and mention the steps you took.
Step 2: Confirm you have the correct drivers
:warning: Skip this step if you are not on Windows :warning:
We use libusb drivers for MacOS and Linux and they come packaged with the application. You should not need intervention for these operating systems. On Windows, we use WinUSB drivers. These must be installed once. If the automated tool is not working, please follow these steps:
  1. First power up your Bullet
  2. When it is ready connect it to your laptop/PC using the supplied USB-cable
  3. Download Zadig from here: https://github.com/pbatard/libwdi/releases/download/v1.4.1/zadig-2.7.exe 12
  4. Run the downloaded file (zadig-2.7.exe)
  5. Choose “Options” and make sure “List All Devices” has been checked
  6. Choose the “Aillio LTD….” Interface. If there is more than one interface choose the one that ends with “1”
  7. Click ”Install”
  8. When the installation has been completed then restart RoasTime 4
Step 3: Restart everything
If you have made it here, you definitely have a software issue. Sometimes we have seen the roaster remaining unreleased after a crash or some other issue arising which results in us being unable to claim the roaster again.
This situation should be able to be resolved by:
  1. Unplugging the roaster
  2. Unplugging the USB
  3. Closing RoasTime
  4. Plugging everything back in
  5. Starting up RoasTime
Step 4: Submit a ticket
Submit a ticket to [email protected]. This will be redirected to our software team and either I will help you debug via logs or jump on a call with you to debug personally.
I’m not seeing a deps folder. I followed the steps but once I get to the RoasTime folder in the Library, I don’t see deps. Is it possibly called something else?
A quick addition - RoasTime does not support ARM (like Hummingbird) processors.
I understand an update is in the works.
So I updated my Bullet on Dec 6th and when Roastime opened, it showed that my Bullet was not connected. I followed these steps but, that didn’t work. After reading more about it I found a how to which said to delete the dependencies directory (can’t find it again now), and after I did that and opened Roastime, it would not open. Something about a “backend” issue. Then today I found an update for Roastime after the Tech said he rushed the original update. I run on Windows 11, anyway, after I loaded the update and tried to open Roastime, I got the same error stating a “backend” error. Finally, I went to the Roastime directory and saw a lower case roast-time directory just below the Roastime directory that housed the Dependencies directory. I change the name of the Roastime directory to RTBK and changed the name of the roast-time directory to Roastime and open the Roastime application and it asked me if I wanted to create dependencies, Yes or No, so I selected yes and walla the application opened and I was once again connected. The app then sync’d with my info and there was all my roasts and recipes. Just in case you’ve tried everything and it still fails, you can try what I have done.
Hi all,
There’s a recent software change for ARM chips compatibility. If you are having a USB connection issue on a Mac, please try redownloading the RoasTime:
Best regards,
Kevin
The ARM version of RoasTime is wonderful in that it is much faster than the x86 version on Apple Silicone.
One thing I would suggest to Aillio is to update the default “Download” button on the website. A Mac user who wants to download the app from the homepage gets the x86 version by default. You have to go to the downloads page to see that there is another option for Mac. I think many users might miss that subtlety.
It should automatically download the correct version as the website can read what OS you are browsing with. If this is not the case then it’s a bug.
I visited the website to test and found that the general download link now directs the user to the list of the different OSes and versions for x86 and ARM. I think this is perfect.
Again, I encourage Apple Silicone users to double check and make sure they are using the ARM version, because they might have inadvertently downloaded or kept the x86 version and the ARM version is much faster on startup and basic functions. I use the x86 version on the Mac that is always connected to the roaster, but keep the ARM version on my M1 MacBook Pro to inventory beans, create recipes, review roasts, etc.
Will this version work with an ARM Windows machine?
Tip that I got after contacting support:
  1. Connect the Bullet to your MacBook before turning the Bullet on.
  2. Run RoasTime, then turn the Bullet on.
So from now on, I’ll start RoasTime and connect the roaster before turning it on.
