The “first crack start” input box isn’t showing my input.
I found that I can input my time in another input box, then copy that over into the erroring input box.
I’d say there’s something funky going with the code wired up for the first crack input box.
How can you edit first crack in RoasTime 4.6.16? I can not find that edit box.
Found it. Done in Roast.world, not in the app
In RT4, open the roast and choose Edit in the 3-dot option upper right. Once the Comemnts box is open, down at the bottom are the values for YP, 1Cs, 1Ce, 2Cs …
When you click the Time field you should see up/down arrows for editing the value. Then Save.
In “Your Roasts” list you’ll see three vertical dots at the far right side. Click on them and the drop down menu will show. There you will find the “Edit” button. Once you click on it, you can edid your FC time and more. If you open a single roast, the dots will be located in the upper right corner, next to preheat temp. If you can’t see the dots, check if your sidebar is collapsed and/or go fulscreen F11 or Fn+F11 Windows, Fn + F or Control + Command + F Mac.
