Someone told me my IBTS and BTS should get closer near the end of a roast, if not merge, and suggested I should replace it. Is this accurate? Mine stay parallel pretty much the whole roast. I couldn’t find information confirming this. Thanks
Ignore that someone. If you try to roast a 1KG or 1.2KG, they will. On smaller batches, up to 0.6-0.7KG, like the ones you’ve been doing, they won’t. Never ever. Maybe they would if you started roasting without preheating your machine, but you don’t want to do that.
Thanks for the response. . Good to hear that. Back to roasting!
Hi, to be honest, I only watch at the Bean temperature. This is the only temperature, what you can compare to another Roasters - sample of bigger ones
