I installed a new IBTS assembly on a Bullet recently upgraded to V2. At first everything seemed fine and then in the middle of the roast the IBTS just failed. Temp dropped to -273 in the graph, zero on the display. The roast finished fine, although I had to use the old bean temperature number and I wasn’t getting anything out of the drum.
Here’s the graph:
And the log file has this:
HiBoard V2.0 / Serial 75 / Firmware 602
Info 29696: 65535
Error 13: 4
Error 15
These errors repeat about 100 times.
I tried cooling, unplugging and starting again. On every restart I get the beeps that signify an IBTS re-initialization. I replaced the IBTS because I was getting this from the old one after my V2 upgrade.
I’ve already sent this on to Matt at Aillio, but I wondered if anyone has been around this block before.
