IBTS Rate of Rise on Bullet Display
Hey all.
When I’m roasting the Drum Temperature (DT) display on the Bullet shows the Bean Temperature RoR. I’ve read through the manual and can’t see anyway to change this to show IBTS RoR instead. Can anyone please advise if this is possible?
Thanks in advance
On the upright corner you will find the burr under your name if you were using RT4 or in the right side menu for RT3. You will find it under roast config.
Thank you for the reply. I can see the IROR in Roastime just not on the actual display on the Bullet itself. There doesn’t seem to be the option to adjust this in any settings page from what I can see.
The filter algorithm to calculate the IBTS-ROR is only implemented in RoasTime, and for now cannot be shown on the Bullet screen.
Thanks Jacob,
I appreciate the reply. Do you reckon this is something that could be added in in later firmware updates?
Thanks.
Yes, it is something we will try to do.
