Incorrect toast appearing in RoasTime
I’m getting “Your roast is coming to temp soon” toasts when…it’s not. The roaster is just idling.
Is there a way to turn these off, or is this bug?
Version 4.6.26 (4.6.26) Mac OS
Hi Morgan! Thanks so much for flagging this, and sorry for the confusion. You’re right, it’s a bug, not something you did :slightly_smiling_face:
Here’s what was going on: when a roast starts with a recipe that ends on a bean temp or IBTS temp, the app was peeking at the temperature of the hot, empty drum just before the beans went in. That reading is way above the recipe’s end temp, so it got a bit too excited and thought your roast was almost done. The message is meant to stay put so it doesn’t flicker, which is why it just hung around for the whole roast.
There’s no setting to turn it off for now, but if you click the message it’ll close and stay away for the rest of that roast.
Good news: it’s fixed and will be in an upcoming update! After that, the message only pops up when your roast is genuinely getting close to the recipe’s end temp. If the end step also has a time, you’ll get a little 10-second countdown instead. We also tidied up a couple of related cases where some recipes could end the roast or change settings right at charge.
And if you ever see it pop up when no roast is running at all, just give me a shout. That would be a different thing and I’d love to take a look.
Thanks again for reporting it!
@ekpiti I’m still seeing this behavior, despite several updates coming through since our conversation.
Is this still in the works, or should I have seen it fixed already?
Hi Morgan! Sorry, I should have been clearer about the timing.
The fix is done, but it hasn’t reached your app yet. The updates you’ve had so far were for other parts of RoasTime. Your Client version is still 1.215.0, and the fix is in 1.215.1 and later. It’s rolling out now, so it should come through on its own with your next update.
If you still see the message after that, let me know and I’ll take a look.
Thanks for your patience!
