Hello everyone,
Couple of days ago, I replied to @gabyritaseek.qiAO, suggesting to run the aillio on max drum speed and minimize the batch, which already had been done and there was no more room for any thing to do.
But in the same topic “ What would you suggest to improve Aillio Bullet design!?”, one of the features I suggested was to add a cap on the exhaust.
I used some aluminum foil layers, squeezed them, tried as much as possible to fill the hole.
It wasn’t fancy
, and this is how it looked ![]()
I know, it will not block the exhaust 100%, but I was hoping to trap as much heat as possible while the fan is on a high speed.
And this is the result of 2 roasts for the same beans, one entered the milard phase with F3 and ahead of the FC, turned to F5 to kick the smoke.
The other roast, I used the handmade cap i shown to you earlier entered the milard phase with F8 until ahead of the FC turned to F5 and removed the cap.
I managed to roast on F8 during the milard without using the momentum. I assume i was able to expose the beans to a higher rate of hot airflow thanks to the exhaust cap.
Did it work?! I still don’t know as the roast is still fresh, I didn’t do cupping yet.
Does it make any difference?! As a roast chart it did, but how this higher airflow will impact the cup, thats what I will find after the cupping.
The experiment is still new, I don’t know if anyone else done it. if did, hope they can share their experience.
Last thing, normally it takes somewhere between 23-25 minutes for my roaster to be ready and the pop message appears. This time, it took less time, 18 minutes (%33) less preheating time.
This is a mere single experiment, need more trials and observation.
Thank you
