Has anyone got the Linux version of Roast Time to work on a Chromebook like the PixelBook? I tried running it from the terminal and it throws an error fuse: device not found, try modprobe fuse first cannot mount appimage, please check your fuse setup.
After some research it could be that fuse is not part of Crostini yet but when I use the --appimage-extract command and then try ./AppRun I get the error Desktop file is missing please run AppRun from within an AppImage. line 50 /app/aillio-ts no such file or directory. Are the extracted files from the app image required to be put in a different folder?
