Is there a direct button that allows you to click on a user name in the community forum, and look up a users roast history on roast world?
You can search in RW for the user. It’s two different software, the forum is a 3rd software called Discourse while RoastWorld may be bespoke software.
That makes sense. I have been using the search bar, but on my phone and slow data, and the weird roastworld squeeze on a tiny cellphone screen, it becomes a bit cumbersome. Like I cannot see if I have typed the username correctly, and can only see the last letter or sometimes none at all. So, was sort of hoping I just missed where a direct link might be.
There is no Wi-Fi where I live, and cellphone use is spotty. Luckily forums are not usually data heavy.
Try landscape your phone or maybe on a tablet device instead. I use RW on an iPad fine.
Caveat, the search algo in RW is a bit weird in my opinion, but if you copy/paste the user’s name it should work just since that will then be an exact search.
I hear you.
Also, when I try to copy a username, I only have the option to copy a link. So unless I can find a username in another format. Anyway, I do appreciate the suggestions.
This is landscape mode on iPhone, can’t even see the last letter.
