Ok, I’d like to create my own Mocha Lattes at home. I am already making awesome espresso with the Bullet.
Please share your favorite recipe. My hope is that someone is using actual chocolate (powder) and minimum amounts of sweetener that if necessary is hopefully something other than sugar.
Howdy:
You’re probably going to have to experiment yourself, but I’d recommend starting here assuming you are using 2oz espresso. Used this recipe the other day for homemade hot chocolate:
- 8oz milk
- 5grams unsweetened coca powder
- a drop or two of vanilla extract
- 1 tablespoon chopped chocolate of your choice or semi-sweet chips
Put the milk and coca into a saucepan and heat on medium to medium-high. Whisk constantly. When the temperature reaches about 180, add the vanilla and chocolate/chips. Heads up–don’t let the temperature get above 200-205 or you’ll more or less ruin the milk.
add to your espresso and boom. Should probably be delicious!
David
