So am trying to find the sweet spot for the natural , i started it with p5 and d7 with f7 , am roasting a 200 g batch not sure about the correct preheat temperature, would appreciate to hear if someone has roasted it and what they tried
Regards
Regards
Post a profile so that we can see what happened?
Hi -
I just roasted a bunch of natural Ethiopians (not yirgachefe, though, they are Sweet Maria’s Shakiso Bookkisa) on my Bullet and they’ve been great.
But first: I highly recommend reading the article aillio posted on medium about how to start roasting great coffee with the Bullet. In this article they give you a “sample” recipe for roasting light roast coffee. I’ve found that it works great to start.
Give that a try - it will tell you what to use for preheat temps depending on your batch size. Also, it will then tell you “start with this power level, then at 165C, lower the power level & up the fan” etc. It’s really useful.
Last couple things:
I’d guess that the slower drum speed is what led to you smokiness… the surface of the drum may have burned the outside of your beans.
I’ve had success with Ethiopian natural using:
You can see this roast profile I used for a natural ethiopian. Here’s a snip below for reference.
–Matt
Thanks alot this is really helpful
With lower batches, I found that I can’t freak out on random crazy ROR crashes or spikes or you will be just jumping with settings all over the place. Just make the change you need and don’t worry if see all of the sudden a huge jump down. It’ll rebound and go in a predictable downwards pattern.
