I use playback mode regularly and find it to be very reliable at tracing a roast profile until yesterday.
I roasted 500 gr of indo bean using playback mode and I kept getting low RoR even after applying more heat. The problem did not go away after I tried the following
Different bean and roast profile
Cleaning the roaster including exhaust fan and pipe
What did you do before this happened?
Things to consider
a) If old profiles were with a dirty IR glass then the preheat temp would be different
b) If the chaff filter was dirty then roasts might be faster due to less airflow
c) Environment, ambient temperature
d) bean density could perhaps have an effect
e) Power plug voltage if this is lower for some reason then in V1 the power could be less
thanks for getting back to me so quickly … here are some of the things I did
I did back to back roasting of 1 kg load x 3 on New Years Eve, clean chaff and soak chaff filter and replace the chaff filter and then on New year I roasted some more and observed the problem of low RoR as well as P and F settings change without my input (this happened after I got out of playback mode)
Things to consider
I suspected the same, so I opened from panel and wiped IR Glass which wasn’t too dirty anyway as I do this regularly. the problem did not go away
I just cleaned and soaked the filter (it’s shiny) before the problem arose
I live in Indonesia, so ambient temperature is pretty stable
I tried a different bean that I am familiar with with my regular profile and I am still seeing low RoR
No other appliances connected to the circuit … but I will try again and report today
I have seen the opposite issue with the playback mode. I follow very closely up to the Yellowing point and then my roast takes off on me. Sorry, I dont have a copy to show. I assumed (maybe incorrectly) it was a V1 vs v2 issue
You can always contact Aillio with your problem and serial number and we will try to check the logs if you have been roasting with RoasTime and you are connected to the internet.
